  #55 (permalink)
Old 07-19-2011, 04:08 AM
Rob. Smith Rob. Smith is offline
Liam,
A good trick to attain a complete coverage is to have a 'spotter' with a bright lamp standing by. Get them to have a look around after each coat/pass... as well as having a "spray check sheet". Use 'paint' or something similar on your computer and print up a sheet with a checkerboard design ( squares about 10mm) Black and White checks and then stick it near where you are painting. As you put down a coat of paint do the same on the "spray check sheet". When the sheet is completely covered you have the same on the project.....Then, if there is one side of the panel that is poorly covered. You can blame the 'spotter' !
