Old 02-05-2002, 07:45 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Timing
My crank is stock one grove. My top dead center is marked with a little bump or tit. I know this is TDC because my crank also has the two XX marked at 45 degree for setting my valves. My #1 plug wire at my distributor is right on line at TDC. My rotor points directly at the #1 plug. Tonight I will also check to make sure I haven't made a mistake but I am pretty sure everything is OK.
"Let's roll"
"Be part of Something Good
