I doubt the fuel pump will pump much air. You need to bleed enough gasoline to the fuel pump before you will be pumping much fuel. Air in the lines between the pump and the engine will be pushed out. Air between the tank and the pump will cause the pump to not pump. At least that is my two cents....
I had an uncle say "I learned a long time ago cars don't run without it". I got the gene from dad that makes me play the "Let's see how low you can go before buying gas" game. I got my SPF below empty line, it was sprinkling and we were in somewhat of an area we were not familiar with. We stopped at three stations before we could buy gas. We bought 16.5 gallons....
