Old 07-21-2011, 03:34 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Don't know how tech savy you are so I might be pointing out the obvious. Do you put it in another gear before you put it in reverse? I usually put it in 1st then reverse. This slows down the gear set.
Is you clutch adjusted correctly?
I also noticed if the engine idle is high(like when you first start the car up) it might also tend to grind.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
