Reverse is not a syncro meshed gear, grinding would be normal, the solution is as stated by jams just touch it into 5th for a second and then into reverse. the syncros for 5th (or any forward gear) will slow down the gears inside and allow you to get into reverse without any grinding. If that doesnt help then check your clutch adjustment.
