Attaching the lower shock mount bracket to the SVT suspension arm. A litte grinding required.
Test fit the disc, needed 3 brakes
Welding the spacer, which keeps the disc in the center.
Drilling two additional holes and mount the disc with a cross brace on the bottom
Upper adjustable shock mount - like the front ones.
For the first time on her "own legs".
Shot from the top.
Stiffer plate to rigid back frame half and base for roll bar mount.
The front shocks have a 20 degree, the rear shocks have a 24 degree angle. The ride height is adjustable 7 inches. This makes it possible to use any coil over shock configuration.
