Originally Posted by G-Pete
..... it would be exact the same setup- location of the shock mount and sway bar...more or less added work for the same purpose with slight different appearance.
Totally understand. I think the thought and engineering you are putting into this build is spectacular and the progress is pretty phenominal as well. IMHO, the variable shock mount feature is a neat addition. Kudos to you for being out there in the shop plugging away in the Texas heat!
- Allen.
