Hi guys,here is an update on the overheating . I replaced the water pump pulley with a Kirkham smaller one and the temp. is holding at 190 degrees.Increase the RPM and you can literally watch the temp go DOWN to 180.Now today I will add a shroud and see what effect it has.Outside temp. is 95 degrees.Happydays are here again. I'll let you know what the stainless steel shroud does.It should help beacuse without it I'm getting 0nly 73% of the radiator being used.Back atcha later.
Reason: spelling
