Thanks for the advice and ideas.
I'm just using what was recommended and it was recommended that i use this pressure regulator with a return line to the tank. This is my first 427FE build and i simply copied other 427FE Kirkham builds.
Im using a gauge that is connected directly to one of the pressure regulator ports. Im using a fuel level gauge, so i do not have a pressure gauge installed in the dash.
The voltage at the pump is 12.7
