Old 07-29-2011, 04:28 AM
blykins blykins is offline
Right...
On a Digital 6, you have to tell it to do that. It's on one of the dials.
For a street compression engine I really don't see the need to do that (such as Chris' case) unless he has purposefully locked the distributor out.
It would be perfectly fine to run a set initial and a set advanced timing. Any starter (even including most stock starters) will turn over 10.5:1 without slow cranking.
If the compression were 12.5:1 or the dizz was locked out, then it would be nice to have.
Keep in mind that if the ignition retard was on and the engine was set up with a lower initial, with a lot of ignition retardation built into the box, it would be WAY retarded and probably wouldn't start without backfiring out the carb and throwing an absolute fit.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
