Old 07-30-2011, 06:39 PM
Jcmrant Jcmrant is offline
Cobra Make, Engine: Classic Roadsters, 302
When I did mine I started like the manual says. start small and then center the best you can to get the 1/2" threaded rod in. Once the rod was in I slide the 1.25" bars over the rods and then I marked all the way around. i then used a air body saw to rough cut and then a file to finish. Seemed to work well.
