Old 07-31-2011, 04:20 AM
suthol suthol is offline
Originally Posted by Zedn View Post
The beaming and torsion test is described in VSB14. If you call a test facility and ask for a price on the test it will be a lot. I was quoted $1800 for the test to be done before i found out the manufacturer has already done it. If they wont accept the test from the manufacturer, make your own jig, buy/borrow some gauges and pay your engineer to observe you doing the test. Contact Suthol on here, he has done it on his scratch built clubby chassis.
It would be logical that they should accept a declaration from your manufacturer that your chassis is identical to the one tested.
Liam,
Whoever quoted you $1800 saw an easy buck coming, my test cost $450 + GST.
Having said that I did have the car set up on the jig ready to go along with about 200Kg of steel shot in 20Kg bags and another 200Kg of barbell weights so there was no time wasting.
There was the best part of a day in setup because of trail and error but I will do it quicker next time, obviously if you use the engineers jig and premises he will spend a lot of time ( your money ) setting it up.
Here's a link to some pics of mine on the jig Daves Beam and Torsion Test ( the Datto 1200 ute had 347 RWKw before the current turbo upgrade that's still in progress )
