Old 02-05-2002, 09:02 PM
Toadmanor Toadmanor is offline
Hi again FE: True some 360's DID have low compression but also the Edsel also used the 360 motor in 58 with 10.5 CR and 303 Hp@4600 with one 4bbl which is in line with the 352 of the same era. I doubt that motor has different pistons or rods than the trucks. The original heads on My F-250 Camper special are 70 cc's so have a very low compression which I haven't computed The pistons appear to have the same tops as the typical 390. I haven't pulled them yet so I havent measured their compression height.
You Can Build and Race Your OWN Car
