Old 08-02-2011, 12:33 PM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
I think I remember a thread where the technic was to use a dowel or threaded rod was used.
You would start a hole on the body and insert rod aligning to the mounting hole on the frame, align the rod to be straight on with the mounting hole by elongating the drilled hole in the body so the rod will be able to go straight. Then use a hole saw and instead of the drill bit in the middle as a guide, you use the rod going through the mounting point on the frame.
