  #387 (permalink)
Old 08-07-2011, 05:24 PM
tkb289's Avatar
tkb289 tkb289 is offline
Originally Posted by 289fia_cobra View Post
How goes it on the header/exhaust front?
Herman … excellent question … and while working on the exhaust, I found a problem. In looking at the manifolds, I noticed there did not seem to be much clearance, between the manifold and the frame … and the manifold collectors seemed to put the pipes a bit low. I sent Bob at ERA a photo and he figured out the problem right away ... the motor is sitting too low!
He believes there is likely a stack up of tolerances and that the motor needs to be shimmed up about 1/4". So, that's easy enough to do and when I get a chance will try that and see how things look. Could also be the motor mounts are not correct.
Once that's sorted out, I can put together the rest of the exhaust, going to start with the Dynomax turbo mufflers that ERA runs, then have a short pipe that turns out before the rear tire. Should be a very similar setup as to what Wolf did for 2139 … except not the nice stainless steel pipes and mufflers he used.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
