  #388 (permalink)
Old 08-07-2011, 06:32 PM
tkb289's Avatar
tkb289 tkb289 is offline
[quote=Mando;1144613]
Originally Posted by tkb289 View Post
I was hoping someone could help with advice on water supply to the heater. My cars not on the road yet but I have been thinking about installing a heater valve which I have that's exactly the same as tkb289 has used in the picture. I don't know a lot about how cars work but does it mean that when the valve is off there is water sitting in the remaining line that just sits there until the valve is opened? Would it be wise to install a three way valve that returns the water back into the system through the heater return hose? I may be completely off key here but I thought I'd ask!
Regards.
Originally Posted by xb-60 View Post
Mando - my understanding is that it doesn't really matter where in the heater supply line or return line it is that the valve is located. When the valve is off, it just stops the flow, and there has to be 'dead' water sitting in the line before and after the valve. The important thing is that there can't be air anywhere in the system.
Can you add to that Tim?
Glen
Mando,
Here is my understanding per the ERA manual …
- Install the water shut-off valve in the water outlet of the intake manifold … connect to the lower tube on the heater (inlet) ...
- Connect the upper heater tube (outlet) to the fitting on the water pump ...
- (also) If you are using a heater … drill a small bypass hole in the thermostat next to the bulb so that a small amount of water bypasses constantly …
So in my setup, the water source is from the brass 'T' on top of the intake manifold. Had there been more room under the distributor, I would have mounted the water temperature sending unit there, and used just a 1/2" npt to 5/8" hose fitting, connected to the heater inlet valve.
The water then exits out the 'upper' heater core hose, to the water pump (to the plastic 'T' in my case) that also joins in with the expansion tank. This setup should work, I'll let you know how it goes.
As far as 'dead' or non circulating water is concerned, the valve is only on one side, so there may be some water mixing but probably not a whole lot. One could crack open the valve just a bit to get some recirculation from time to time. Be sure to leave the valve open with bleeding air out of the system.
Hope this helps … anyone else have any input for Mando?
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
