Ask Scorpion if they want to buy you a set to try.
We use the Morel ost of the time unless the customer just wants another brand. We make a note of this if they are somehting that we do not normally use. When you use as many parts as we do you can get a bad one from anyone. We can normally find this on the Dyno when we run the engine or prime it.
I have not used the Scorpion lifters but have used many sets of their roller rockers on our small block builds and have had pretty much zero problems with them. Like mentioned before Morel makes lifters for several companies. I know this is the case with some other companies as well.
If Scorpion gives you some lifters let us know how they work for you. I normally have to buy the parts and then find out how they work by testing them before we will use in cusotmers engines. We have helped redesign many parts for the Ford engines to get them right. this is a part of our business that most epople do not see or understand.
Good luck, Keith Craft
Keith C
