Old 08-08-2011, 05:22 AM
blykins blykins is offline
Default B2 Motorsports 445FE Complete Engine
Complete engine, dyno tested and ready to drop in the car. Compare to other builders' engines that lack the details....oil filter adapters, alternators, water necks, coils, coil brackets, etc.
*Machined Ford 390FE Block
*ARP Main Bolts
*Scat 4.250" Crankshaft
*Scat 6.700" I-Beam Rods
*Probe Forged Pistons
*Mahle Rings
*Clevite Bearings
*Professional Products Balancer
*Felpro Main Seal
*Ford Racing Timing Chain
*New Crank Spacer
*Custom Comp Cams Hydraulic Roller Cam
*Morel Lifters
*Melling HV Pump
*ARP Oil Drive
*Moroso Front Sump Pan, Pickup
*Edelbrock Heads
*T&D Rocker Arms
*Trend Pushrods
*ARP Head Bolts
*Edelbrock Performer RPM Intake
*Edelbrock Water Pump
*MSD Distributor/Plug Wires
*Ford Racing Valve Covers
*Quickfuel Carb
*Pulleys/Alternator Bracket
*PCV Valve/Breather
*MSD Coil/Bracket
*1 Wire Alternator
*Oil Filter Adapter
*Water Neck
$11999
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
