  #56 (permalink)
Old 08-14-2011, 10:13 AM
jhv48 jhv48 is offline
Originally Posted by Bartruff1 View Post
not perfect but another road force balance...18-20lbs of cold air pressure...and (something new)...about a 1/4 turn of the bolt adjustment of the pinion (?) and it is about 75% gone...now...since the 65mph shimmy is not constant but reacts to the road surface , the next step for me will be the Micky Thompson tires in a few years ...then the ball joints...the steering tightening didn't cost anything so I would look there first...
Your symptoms sound the same as mine. Front end vibrates sometimes, not all the time, and the wheel feels loose when you go over bumps in the road. Not a firm feeling. Real annoying.
I did all the balance and alignment tricks. Changed wheels and tires. Still there. Replaced the stock ball joints, all gone. Ride is now smooth and more solid. Just do it!
You can either live with the annoyance or replace the stock ball joints and be done with it.
Jim
