Old 08-15-2011, 09:25 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
John,
How about a Mallory 4309? I run one on my car.
You could have the reg referenced to manifold vacuum.
15 inches of idle vacuum with the reg at 2psi, would give you 9-10 psi at WOT.
Or you could replace the spring with a softer rate and get 2-8ish psi instead of 3-12 psi (Mallory factory spec).
Gary
