  #45 (permalink)
Old 08-17-2011, 01:08 PM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Arno,
Now that you are close to receiving your engine, here are a couple of pointers that I had to learn the hard way.
1. Remove the tranny tunnel before installing the engine. It is held on with about 10 screws. You have to take the seats out, but it makes it much easier, plus you have to remove the tunnel to get the driveshaft in (well, at least I did as it was the only way to get the rear flange past the differential enough to slide the yoke into the tranny).
2. Remove the clamshell tranny mount from the frame and attach it to the tranny with the two bolts, then when you are in position, slip the single large bolt through the mount and secure it to the frame and finish tightening the other two.
I wish I noticed how easy it was to remove the tunnel at first. Not noticing it at first cost me an additional couple of hours. Good luck!
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
