Old 08-21-2011, 10:26 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Gaz64,I took some ohm readings and this is how they turned out. This is with the sender on a bench one probe on the wire stud and the other probe on the part of the sender that would be in the oil pan. BTW I used a heat gun to heat the sensor and then used an infrared gun to measure the temp.
Cold 72F 8.42
hot 212F 107
super hot 300F 70
I would think super hot would have a higher value.
Let me know what you think.
Thanks,
John
