Old 08-23-2011, 04:18 AM
blykins blykins is offline
Pressure plates are designed to be used with a specific purpose and a specific air gap using a particular disc thickness. Since that Street Twin clutch that you have there is meant to be used with two clutch discs and a floater, I don't think that you will be able to use it with just one single disc.
Also, that is a custom application, and the Street Twin pressure plates are to only be used with the included flywheel. It's not a normal Long style pattern.
I can get replacement discs for you to match your input shaft dimensions and you can reuse the flywheel and pressure plate that you have.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
