I beat on my car pretty hard, and this works pretty well for me:
No gaskets anywhere in the exhaust system. High temp silicone only.
SS Grade 8 (brand, not rating) header bolts. I gave up using the locking tabs a long time ago - too much of a pain to R&R. On some spots I use the cheaper black metal bolts that FFR supplied. I hand tighten to about *that* much. All bolts have a split lock washer on them. I check them every so often, but they never come loose.
Standard bolts and nuts on the side pipe flanges, standard flat washers. They happen to be a grade 8 (rating, not brand) fine thread. But that's only because I happen to have a box of them lying around I didn't know what to do with. I tighten them down good and they never come loose. They do look a bit rusty and discolored from the heat. Maybe the rust is a natural thread locker?
As the engine and exhaust warm up and cool down, they expand and contract at differant rates. Sometimes the joint is tight, and sometimes it is not; especially with metal gaskets like copper or alum. When the joint is not tight is when the nut will vibrate loose. This is the perfect spot for a split lock washer; they only work when the fastner comes loose a little bit, and allows the ends to spread out.
Put an internal star washer under the bolt head, a split lock washer under the nut, and no flat washers. TTYF. You might even try a locking nut with a internal star washer between them.
If they still come loose, the problem is not the fastner. The problem is the joint is not flat, and is allowed to rock.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
