Old 08-24-2011, 02:37 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
You can do a simple resistance test on a coil to determine if it is in good working order. Consult the MSD website for the baseline numbers you need to verify on your coil type. Visually inspect for any oil leaks or swelling on the coil body. Remember to always give a "hot" coil and the ignition system due respect..unless you like being a sparkplug...
SPFWiringDiagrams@Comcast.net
