You guys know you can count on me to be there....I can see I have many mods to perform on my car before June if I want to run with the BIG DOGS!!!
Jerry, I'm sorry I forgot to give you back that rubber ball you lent to me to keep the fuel from sloshing out of the filler cap. I think that ball was causing a vacuum in my fuel system, which was why I kept on bogging out on every first lap I ran and then seemed to operate at less than full power (maybe Jerry C's problem also?). When I got home and remembered that I still had the ball installed under the cap, I went to pull it out and it was about 1/3 drawn into the fuel inlet pipe, wedged in very tight. I've got to figure out a way to prevent the sloshing without causing the system to lean out due to vacuum.
Joe, how did you make out with your car? Have you identified the hydraulic problem yet?
Ruble, I forgot to tell you, I watched you quite a bit on Saturday and I thought you were driving really well. Very smooth and consistent through the toughest sections of the track.
Dino, are you planning on installing a speedy-dry dispenser on the back of your car for G'ville #3???
Mike
