May I ask some questions?
1. What is your static compression?
2. What is your cams duration at .050" lift for both intake and exhaust.
3. What is your cams LDA?
4. What is you cam installed at?
5. What type of fuel are you running?
6. What is your final gear ratio and tire diameter?
7. Is you intake manifold a dual plane or single?
8. What does you car weigh?
9. Does your MSD distributor have the vacuum advance or is it the mechanical advance only?
10. What type of starter do you have?
thanks
Concobra
