  #392 (permalink)
Old 08-29-2011, 10:41 PM
tkb289's Avatar
tkb289 tkb289 is offline
Wolf,
You are correct … things have been quiet … a bit too quiet.
I have made some good progress but it's been slow going. My goal has been to finish the rest of the install with as close to the ERA level of 'attention to detail' as I can get.
Fabricated some shims for the motor, they are out for powder coat. I am tweaking the throttle linkage set up to get it aligned per the instructions. Also added a special screen to the upper radiator hose, to keep any rust from the motor getting into the radiator. Once the motor has a few miles on it, I'll probably take the filter out. I have also made some changes to the slave cylinder setup, to improve the linkage geometry. It's installed, all I need to do is bleed the system and see how the setup works.
I will have some time over the up coming labor day weekend to make some more progress, so by early next week, I should have some photos and updates to share.
Thanks for checking in!
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
