Old 08-30-2011, 01:27 AM
SeanO's Avatar
SeanO SeanO is offline
Default Feedback to a car
Hi All,
I have a second hand car I am looking at purchasing with the below spec’s but just wondering if there are any thoughts to things I should look out for?
I will get a workshop inspection done by the RACQ but just curious if there are other things I should consider or even instruct RACQ to look out for?
Car is approx 15 years old since first date of engineering report.
Engine: Imported Ford Windsor out of a Mustang. Reconditioned (fully) with unleaded compatible pistons, sports cam, heads were balanced by an engine builder which makes the engine run smoothly, Edelbrock inlet manifold and a 4010 600 cfm Holley fitted, original exhaust manifold, recently replaced plugs and leads.
Gearbox: Dello modified Toyota Supra 5 speed manual.
Suspension: Modified Jaguar series 11
Differential: Reconditioned Jaguar XJ6
Steering: Modified Commodore rack
Stopping: Huge Jaguar disk brakes
Chassis: Factory built square tubing with one piece steel floor
Body: One piece fibreglass shell
Cooling: Modified Commodore radiator with thermo fan.
Weight: Approx 1100Kg.
Peddles / Master cylinder / Brake Booster: from a Sigma
Hand Brake: Honda Civic
Thanks,
Sean
