  #25 (permalink)
Old 08-30-2011, 05:25 AM
strida strida is offline
Cobra Make, Engine: Classic Revival #3508 6Litre LS2
After advice earlier in this thread I eventually purchased QA1 single adjustable Proma Stars from Summit US, when I needed springs I spoke to Neil Streeting who put me on to Rob of Eibach springs at Warriewood NSW (Manly area). I also used softer helper springs to prevent the springs from unloading, similar to what Andrew mentioned above
Merv, I needed to get 2.5" ID springs to fit the QA1 shock collars which made fitting to the CR suspension a bit on the tight side with the larger OD springs, particularly on the front.
A belated thanks also guys for the advice I received early on in this thread and all the other info I've picked up along the way.
Dennis
