almost same as elmariachi.........
428 w/4.25 stroker crank (455 ci) 10.1:1 cr, alum heads, Comp 294 flat tappet hyd, MSD 8594 distr w/black bushing, but I think I have one blue & one silver (?) spring in it now. Currently set at 18 initial & 36 total.
Once this summer heat in Okla breaks, I'm thinking of bumping it to 20 & 38 and see how it does.
Base timing of 6, 8, 10 is from the old reference books back in the 60's. I started at 8-10, it was very sluggish and idle temps were horrible!
Good luck!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
