Old 08-31-2011, 01:03 PM
strictlypersonl strictlypersonl is offline
Originally Posted by Mdman352 View Post
A Jag rear was made for a 230 HP 6 cylinder with 700 series bias ply TREADED tires. When you put 500 HP and MT drag radials in their place the result eventually will not be pretty, ...
Jaguar ended up using it in their 12 cylinder cars too. Much heavier cars, with up to 4.11 differential gears with the overdrive transmissions.
Shelby chose to use the differential (with very minor casting changes) in the 427. True, it wasn't meant for drag racing, but it has held up pretty well otherwise.
