Old 09-01-2011, 01:42 PM
DAVID GAGNARD's Avatar
[QUOTEI talked to one guy who said he would fill in all the seams, then DA sand the gel coat, fix pin holes.
I can't recall if he said put a primer on, I think he did.
][/quote]
After re-reading your post,filling the seams and "roughing" them in with a DA sander is fine,unless the body is in very bad shape,there is no need to go over the gel coat with a DA sander and I would advise not to do it, way to easy to screw it up.....
Once the seams have been filled/sanded/primed, all that would be needed is to sand the entire car,then prime it/block it and re-prime.....
On any paint job, the prep work is 95% of the labor and without proper prep work, the best painter in the world can not do a good paint job!!!!!
As Jeff said, painting a Cobra from start to finish in the paint booth should take one day,depending on the body and work needed to get it to that stage,it could weeks to months!!!!!!!!!!!
David
DAVID GAGNARD
