Old 09-03-2011, 11:36 AM
Tony Ripepi's Avatar
Tony Ripepi Tony Ripepi is offline
Cobra Make, Engine: TBD
Hi Kerry,
As you go through the build the thread should be in the scratch build segment of CC and you will be better served with comments, input etc. from members that have the same interest.
The reason I posted Chuck's page was his Cobra replica build from an original frame and the process he went through. The coupe was built from two frames, one for the buck and another that the car actually ended up on. The build of the super leggera wire cage may be something you would want to investigate as well as a buck for your skins on the Cobra.
Chuck is an amazing craftsman with an enormous wealth of patience and focus on doing things correctly from the beginning to completion and from what I have seen so are you.
Best Regards,
Tony R.
