Picture request of fuel system related components
I'm asking all you good people to show me pictures of your throttle return spring bracket. I may make a change to mind if something looks better. Also, it seems as though the angle of the fuel line going to my quick fuel carb is slightly different then the previous Holley 4160 and 4150 I had on it. Seems crazy but now when I went to hook up the rigid fuel line running down towards the frame it conflicts with the heater hose going to the intake. If I had the space a 1/2" carb spacer it would give me plenty of room to clear the hose. However, with my current air cleaner setup it would probably make contact with the hood with the spacer. So I have the option of changing out the fitting of the intake or I'm considering running the fuel line from the carb towards the rear in lieu of the front. Anyone have some pics of your fuel line setup that you are pleased with for my consideration? Also, with this configuration where did the hard fuel line from the tank teminate?
