Hi Dave,
The flat needle rollers fit between the spring and adjusting nut. The qa1 number is 7888-109, works a treat. With regards to the bushes all you do is remove the circlips for the spherical bearing, pop them out and the nylon inserts are 2 piece so they just push straight in, no probs. Got it all from VPW. Can't supply any pics until I get the car back from the trimmers.
Cheers Kyle.
