Old 09-06-2011, 07:12 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Hmmm. Not really convinced yet.
Think of running Alpha-N, but might also try with MAP- sensor. If interconnected plumbing is needed (I wouldn't think so?), I suppose you use tubing to connect all 8 runners from somewhere below(?) the butterflies into a common box or whatever (and that's it?). That would be where the MAP sensor would go.
When it comes to cam, I would go with quite wide lobe separation, 110 +, but there will be quite some overlap- I would guess it wil have a RPM band to 7500 or 8000.
The ECU will be of a newer model... Will run wasted spark with 2 x 4- towers and seqential injection.
I'm not sure about this: "Maximum power from a maximum build engine will come from a large 4 barrel TB. That big plenum underneath gives you a better fuel charge. " When I think of it, yes- OK- if you bulid a max Hp engine of a certain volume/stroke etc- let's say a a 800- 1500 Hp 347 drag engine, it might be so.
But let's take these facts into account:
Fullrace/ HO 4- cylinders run IR (for instance Cosworth roller barrel setups- 300 Hp and 2 litres 9000rpm?)
Throttle bodies are also popular with high output turbo- engines. (600Hp+ 4- cylinders.)
Should we assume no difference in throttle response and not very significant difference in Hp/Tq between a 4- barrel and IR?
Now I will look into crossram manifolds. Have seen them available from somewhere- athough I cannot remember where. (With a new manifold I could keep my Weber setup on a roadcar!)
Thanks for the input. Need more to be convinced!
