Old 09-06-2011, 12:08 PM
blykins blykins is offline
Default Leftover Parts Shop Sale.....
Got a few items that need to exit the building...
1. K1 Technologies LSx 4.000" stroke, 2.100" rod journal, forged stroker crankshaft. Brand new in the box. Customer started a stroker LS build and changed his mind. Lists for $785. You can have this one for $700.
2. Probe SRS Pistons, 4.000" bore, 4.000" stroke, LS application. All brand new. Comes with new set of Total Seal moly rings. $600
3. NIB Comp Cams custom hydraulic roller camshaft, LS application. 247/254, .623/.623, 110 LSA. $300
4. NIB Comp Cams billet LS timing chain set. $100
5. Set of C8AE-H FE heads....need cleaned up, valve job, etc. $50
6. Ford 390 crankshaft....will need turned .010/.010 - $50. Can also have ground for you.
7. (2) Jag 4HU empty center sections. $50 each.
8. Jag positraction differential. $50
9. Brand new CHI 3V 4150 9.200" 351C intake manifold $550
10. 351C 4-bolt block, sonic tested, pressure tested, bored/honed, align honed. Needs square decked to suit rotating assembly. $500. Can also finish machine work and ship.
Prices are negotiable (within reason). Check back for more parts being added.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
