Old 09-07-2011, 04:43 PM
AL427SBF AL427SBF is offline
Default Small Block Ford Power Statistics
Thought it would be nice to see what kind of power the small block guys are getting these days. If you are one of them and don't mind sharing I would be curious to see what the range in HP & Torque is. Filling out the table below will help put it all in context, thanks for your input.
Displacement:
Block Type:
Compression Ratio:
Caburetor Size/EFI:
Peak Crank HP @ RPM:
Peak Torque @ RPM:
Other: Anything else "trick" you have above and beyond a street performance motor.
