Something just came to mind... the bearing, if it's also Ford T-Bird, is split on the inner race. When you press the hub back together, you have to make sure to press the inner race firmly together. If it's not pressed together correctly, it came loosen up and get floppy.
While you have it apart, you might want to replace the bearings. Not that they are worn out but it's just such a pain to take apart.
Alba gu brąth
