Old 09-08-2011, 09:00 AM
SSSammy's Avatar
SSSammy SSSammy is offline
Default Leaky Jag Stub Axle Seal :(
After recent routine abuse at Hallett, my right rear stub axle seal is leaky. Gear lube is not on the brake rotors yet, just dripping off the bottom of the stub axle flange and the caliper, onto the pivot shaft and then garage floor. It is leaking all the time, even sitting still for days. No Run N Gun in two weeks unless I can remedy this pretty quick.
Have searched the ERA Forum, but don't see much on how to replace one or both seals, can it be done without dropping the cage, can I do one side now and wait on the other one? I have read some Jag forums and I see it is a very complicated task, some can do it in place, but recommend dropping the rear end for better access.
I called Coventry West about the rebuild parts and they are not sure on which seal kit to recommend because I have the custom 31 spline stub axles installed by Mike Bontoft at CWI (now out of business). I guess I will disassemble the thing before ordering and see if the dims are stock Jag or not. Curious if anyone with this setup has any tips.
thanks and regards,
Sam
