Old 09-08-2011, 08:07 PM
Ant Ant is offline
Default Efi
Originally Posted by fordracing65 View Post
I would never use a carb, the guys around here are so good at tuning it, its a no brainer if cost isnt a factor, just think, top fuel cars are fuel injected, formula one is fuel injected, so why wouldnt you want your cobra to be.
Carb setup properly will get the job done on the track, and make as much power as EFI. To be honest I would put a new LS7 in this car if I was doing it again mainly due the Yates manifold etc making my scoop bigger. The advantage I would have with a 505bhp LS7 would be enough power, drivability and almost 30mpg fuel economy instead of probably 5 - 12mpg with the carbed Nascar engine.
If you were looking at it from a replica point of view (not a lookalike) then you wouldn't use EFI.
Ford engine is still better than GM in my lookalike AC Cobra!
A J. Newton
The 1960's rocked!
