Need help with water pump gasket, Windsor
I know this is pretty basic, so just checking.
My 418w has sprung a "pin hole" spray type leak along the lower left side water pump gasket joint. Only leaks when get's hot or run hard and took forever to find. Pump is fine and temps are fine since it doesn't leak under normal running.
What do I need to look out for in replacing all the gaskets on the front of the motor. What will be the best gasket (s) to get and replace while I'm at it?
Thanks.
Wayne Rogers in Hideaway, Texas
