  #22 (permalink)
Old 09-08-2011, 11:25 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Originally Posted by AL427SBF View Post
Thought it would be nice to see what kind of power the small block guys are getting these days. If you are one of them and don't mind sharing I would be curious to see what the range in HP & Torque is. Filling out the table below will help put it all in context, thanks for your input.
Other: Anything else "trick" you have above and beyond a street performance motor.
Displacement: 369
Block Type: Dart
Compression Ratio: 10.5
Caburetor Size/EFI: massflo efi tb
Peak Crank HP @ RPM: 435 rwhp
Peak Torque @ RPM: 512ft/lbs @ wheels @ 3000
Trick Flow fac 190 heads, tko 600 road race, 9"diff 3.7:1 posi track lsd. Michelin slicks 27/65/18 & 30/65/18 1200kg street registered.
