09-09-2011, 06:50 AM
KY
A good Felpro or Mr. Gasket gasket will work just fine. Make sure that the pump is not leaking between the pump and backing plate when you remove it. There will be a couple of gaskets in the kit, one between the backing plate and pump, and one between the backing plate and timing cover.
