Sure. Just remove the four bolts holding the tabs together and the rear mount. Then curse a bit
![EEK!](images/smilies/eek.gif)
while simultaneously pulling the pipes apart and moving the back end around. But, it's easier if you
loosen the primary pipe bolts.
Putting the pipes back on, it's mandatory that the primary pipes are loose when you mate the side pipes.
