Old 09-10-2011, 05:43 AM
ted ted is offline
For FE street drivers, my own preference is to use the HV oil pumps. The mentality for this is improved oil pressure at the lower rpms and when idling. For a drag car and reasonable clearances, I'll use the stock volume pump. If the clearances are on the wide side for a 'performance' application, then it's a HV pump again.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
