Thread: Invinca-Shield
Old 02-08-2002, 08:51 AM
Blue Cobra's Avatar
Blue Cobra Blue Cobra is offline
Cobra Make, Engine: Contemporary Classic 427 S/C, Full Roller 429ci Super Cobra Jet, RHP Flowed BlueT & RHP Cam, CompCarbs, AirGap, V12 E-Type Jaguar F+R, 4SBBTL
Default StonGard
Just as an FYI for others, or if you get really frustrated Bish....
Ston-Gard, Headquartered in Bellevue (with US wide locations) will put the stuff on for you, of course not for free.
They will create a template for you Cobra (if they don't have one already) and put the stuff everywhere you want. As a default they cover every leading edge on the car, no matter the curves, bumps edges what-ever, and then give you a 3-year warrantee against chips, dings, bubbles, edges peeling back etc... They computer cut every edge and even have a bow-tie emblem pattern to cut into the stuff (though I don't know if you have the Bow-Tie emblem on you car Bish..and Rich).
If your car get a ding or chip they will remove the Ston-Gard and fix the chip and paint under it (or replace the headlight), and then replace the StonGard shield all for free. They also do headlights, door edges, splash area under your doors, and front side of mirrors. anything which is painted or made of glass.
I wish they could do the entire car but they are limited to 24-inch widths strips of the stuff. They use heat, lots of static cling and a little adhesive to get the stuff to stay in place. All the edges are rolled over the actual car edge to prevent peeling. And it can be removed without any damage to the paint under.
I know of at least 5 people who have Ston-Gard, including myself, and the stuff comes highly recommended. Never needs waxing and the edges mostly disappear except under certain light and the eye of a connoisseur (such as any Cobra owner).
http://www.stongard.com/sgcontent/default.asp
Kevin
