  #22 (permalink)
Old 09-13-2011, 01:12 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
So you put a wood block under your carb and tell me the open top is ugly.
Spacers either add 6HP or cost 6HP (which you can't feel or measure unless you're running strip laps) and need to be dyno coordinated to an intake system. They are not a toy-du-jour for performance improvements. This little tinker project was stupid to start with and what I told you was to prevent what you found out.
Test it without the AC in place to see if your choice is able to help. If it picks up, then get the Xtreme top if you want power-if you're a lawn-chair guy, then forget I tried to help...
And I won't make that mistake again.
I said maybe wood, its phenolic. "This little tinker project was stupid to start with and what I told you was to prevent what you found out." Are you smoking crack? What did I find out, that it fit? What did you prevent? "Spacers either add 6HP or cost 6HP " Oh guru, tell me where you get this from. I have never seen a test where an engine lost power. I have seen tests that pick up as much as 28 hp. You are right not soup dujur. If you read my post, I joked about seat of the pants. Must have been more of that invisible ink. 6 HP from extreme top, maybe, ugly, definantly (sp), wouldn't use it if you gave me one.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
