Old 09-13-2011, 07:34 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default try Pegasus or McMaster/Carr
Try Pegasus.
Replaced the "rose" bushings on my SPAX front shocks with spherical bearings from Pegasus racing supply. The replacements are PTFE, teflon lined and hopefully last longer the stock steels units which were badly corroded.
McMaster Carr probably also has spherical bearings.
Press the units out and get the measurements...pretty standard stuff I
would think.
Also, I have read that KONI will rebuild/revalve the shocks if you think they may have bad seals.
Pete
ERA 289 #2027
